So I'm the happy owner of a brand new 2013 2.5i base model.
And I find that the Bluetooth doesn't seem to understand what I'm saying.
When I tried to pair the phone the system said I couldn't use the name "Dave's Phone" because that apparently sounds too much like the voice command "cancel" :gasp:
Once I got it paired, on like the 10th try, I was expecting my phonebook to load and be useable. But nope, apparently that only works in 4 year old Ford Escapes. Where I've intuitively paired this phone in under 3 minutes without reading any manuals or asking for any help.
So, without the phonebook loading, I tried the "dial by number" function. No matter how many times I've tried to dial by number the system hears "two" as "zero" or adds numbers I didn't say making phone numbers longer than they should be. Or it says "pardon?" as if it's deaf when I spoke loudly and clearly. Is there a microphone volume?
Eventually I had to manually program my home phone number to even test if a call could be made. Thankfully it worked.
But a voice operated system is useless to me if it cannot understand when I enunciate as clearly as an English tutor.
Anyone else having this problem? And what about the phonebook...is that supposed to auto load or am I going to have to manually input 100's of contact phone numbers?
The phone is, admittedly, a POS that I despise. A Motorola Citrus. But, like I said, it paired with a Ford Escape effortlessly. My former employer used Escapes as company cars, and I would pair the phone anytime I used one. In less time than I typed this post.
