2013 2.5i Limited, Special Appearance Package, Brilliant Brown Pearl, Saddle Brown Leather, HK Audio, Moonroof, Navigation
Received a note from my sales person a few weeks ago. Dont know if it applies to earlier models or not.
I just found out that the CVT transmission on the Subaru carries a 10 year 100,000 mile warranty. PLEASE do not change out the fluid on the transmission. It is a closed case and if you change out the fluid before 60,000 miles, it WILL void the warranty. Some quick lube places may try to convince you to change out the transmission fluid. Do not do it as it will hurt you in the long run.
The way the transmission is designed, you should be able to go to around 110,000 miles before you have to have the fluid replaced.
If you do not have the CVT transmission, check with our service department before having your fluids replaced. They will let you know the factory recommendations.
All my best,
Nick
All my best,
Nick
