The mirror glass can be changed, but can be tricky.If I need a replacement, do I need to replace the entire side mirror unit or will a new mirror glass suffice?
However, as your car is new, it should be covered by the full warranty. Take it back to the dealer.
There are probably specifications for the amount of distortion that's allowable on the driver side. If necessary, when at the dealer, compare to other 2013s on the lot and in the showroom.
Dealer would probably replace the whole side mirror unit rather than try to remove and install just the glass itself.
