2014 Outback 2.5 Ltd with Nav, Eyesite, loaded.
I would like to share two discoveries with the 2013 navi:
1. To have the guidance repeat a direction, hit the "info" button and then hit the "map button". Subaru says you can use the handsfree button and say repeat, but it does not work! My solution does and it is quick.
2. To put numbers into the speed dial list that are not in your phonebook, dial the number or find it as an incoming call. Go to speed dial and touch an empty place. Go to incoming or outgoing calls and find the number, then touch it and it will ask if you want to put it in speed dial.
