As you probably know, it's a paid subscription, if you want to access it ....so unless someone out there can access it and publish it on these pages, that would be nice!Does anyone have access to the Subaru Technical Information System:
Specifically TSB # 15-155-12R - Fujitsu Ten (F10) Audio/Navigation Unit SD Card Exchange Information
The file is here, but you have to be logged in to see it.
Who are you asking these questions since there is no indication in your posting above...Well, it looks as though they are addressing the "short notice" to make a turn with a change to the CF card. BUT, Page 24 in the navigation manual for the 2013 Outback says that certain features cannot be used when the vehicle is in motion "WHEN THE SAFETY IS ON" Do you see any reference to shutting a safety off or on? That would be huge. Did it have a wiring diagram that some of the techies here could use to figure out how to bypass the speed sensor?
That's exactly what I am saying. The document said something about making sure the customer knows that the map software on this CF card is the exact same software they have currently. This only addresses audio related issues.Are you saying that 15-155-12R TSB is all related to the audio/music problems and not navigation issues?
I have the same late notice and sometimes notice to turn past the street you are supposed to turn on that you have. I really wish I had bought the base model and done this all aftermarket at this point. Sure I would have given up EyeSight but all these additional headaches are just not worth the added cost.My concerns are related to the navigation/map/turns whereas turn read-outs are spoken (in TTS mode) too short in advance (compared to Garmin Nuvi). And those cannot be adjusted. The only adjustments that I found on that system were the adjustments of read-outs for warnings (you can change the distance, when those warnings are anounced).
I assume you intened to say "it looks as though they are not addressing the..."Well, it looks as though they are addressing the "short notice" to make a turn with a change to the CF card.
Nope, nothing in what I saw.BUT, Page 24 in the navigation manual for the 2013 Outback says that certain features cannot be used when the vehicle is in motion "WHEN THE SAFETY IS ON" Do you see any reference to shutting a safety off or on? That would be huge. Did it have a wiring diagram that some of the techies here could use to figure out how to bypass the speed sensor?
