1 - 20 of 20 Posts
2020 Subaru Outback Premier White
The new 2013 outback with NAVI is made by Fujitsu.
This is the 1st year and I think it has lots of bugs that are not being delt with by Subaru. When on the main map display. The is a function button on the top right hand corner. When deployed it is suposed to slide out. Mine takes aproximately 4 seconds to recognize the command, the about another 4 seconds to start the command, and slow after that and usually times out before the screen fully displays.
1. Can you test this in your car and see if it does similar. Please say if you are in a northern climate or southern climate. maybe temerature
2013 outback limited with Navi. this is a new system by Fujitsu.
I think there are more bugs and no software upgrade to be had as yet. Just trying to determin if I have a defective Navi or are we all in the same boat.
check out this Video on Youtube.
2 - There is also the slide volume control which is set all the way over to the left. Any minute adjustment to the right and its too loud.
any minutiae adjustment to the left turns the volume off.
3. Back up camera confirmation for blue tooth obscuring camera while backing up.
Thanks much everyone.
The slow quick menu problem is unique to you, I think, but the others are common to the rest of us with '13s. There are a lot of posts about these issues and no, SOA doesn't seem to be doing anything about them. Oh, and you forgot to mention that the maps are over a year old.
Thanks much, I think I will be taking it in for some service.
Yes the maps are a year old and it would be a great if as many Garmin products offer lifetime map update, maybe they could at least offer 1 free update sometime during the warrentee period.
Definately a software upgrade would be for the volume slide control and the backup camera.
I almost forgot - late notices of upcoming turns. That backup camera thing drives me nuts. My dealer reported the volume control issue to SOA at my insistence, but nothing came of that. A nav and radio firmware update would make a lot of customers happy.
Sent from AutoGuide.com Free App
Answer to Backup Camera Confirmation Screen and NAVI Delay in function button toprigh
Ok, Answer to
*Back up camera and
*Extreme delay and time out of function button on the top right of map screen.
I contacted a guy named Andrew at Subaru's Customer Service Center.
I provided the YouTube video which was very detailed. He called me back with the worst excuse and possible answer for my problem. He said I had bought a car from the US and I was in Canada and it might have problems finding the satellites. I was expecting a technical review but I got coffee talk from the lunch room from an other guy that works there. Very Very disappointed Andrew.
The delay is actually caused by the Trip Monitor Function. There is a couple of boxes that can be checked or uncheck and to honest, I'm not sure if they were checked by default or if I did it when I bought he car.
They were likely checked off when I started out from purchasing it new.
First box states "Enable Auto Saving" (can be checked or unchecked)
Second line state "Trip Data Base Size" and will give a number in Bytes.
Third Lines states "Save Trip Log" (can be checked or unchecked)
In my case they were both checked. If you have them checked off in your trip log set up, you will eventually have the same problem as the data base gets so large, it will slow down that function to the point that it becomes unusable. Subaru Customer support doesn't know this and will pay the price when dealer start replacing screens, CPU's, computer chips and SD cards. A very expensive mistake for them. But I guess I'm in Canada so what do I know. Thanks Andrew.
The Backup Camera Confirmation Screen can be fixed also.
It under Bluetooth Settings.
The terminology is what I think throws everyone off.
Once again it is two lines with optional settings.
One is referring to the phone Status " on or off"
Second is Audio Player Status "On or off"
Steps, Silver Info Button, Bluetooth, Detailed Bluetooth Setting, Turn Status to Off on Both options including the portable music device
Status is something I think of being always displayed but in this case it is a one time screen at the beginning when you start your car.
It no longer shows up.
I'm going by memory but its close.
Yahoo as we say in Calgary. Go Flames Go.
That's our Hockey team for those non sports fans. :)
I hope this help lots of people.
Cheers
Crawford
I don't know how you figured this all out ( especially since you're a Canadian ), but I really appreciate your efforts. I can't wait to try your solutions tomorrow, especially the one for the [email protected]&) black phone connection notice box.
Good work and Go Sharks! :)
I made both changes and they seems to work well. I don't see that **** phone is connected black box anymore. However, I do see the "... has failed" box when that happens, which is often. Leave it to Subaru to forget to make the "failed" box an option.
Thanks a lot for this !
I noticed my Nav getting slower and slower as the trip goes on - I was suspecting some sort of memory leak related to maybe the ipod playing as it seemed to get worse when I play music (was thinking maybe the album pictures it displays are leaking) - for me it makes the 3d view unusable/too slow and clicking on nav buttons very slow as well
On your instructions below though - Do you mean to uncheck all those boxes ? set a smaller (which ?) value for size ? Where are the Trip settings ?
ps: I have a 2013 Outback
[edit: found that the size isn't editable - unchecked both boxes, click stop recording, and deleted all logs - my nav seems faster now though let's see on a long trip]
Uncheck those Boxes!
Yes, uncheck those boxes. If your going on a road trip you can activate them again. I'm going to take another look at it today but I found... (unfortunately when talking about this stuff, my car is in the garage and not in my office so I have to do it by memory) a button/ tab to clear the logs. My GPS is superfast now.
Too Bad Subaru doesn't have specialist on their 1 800 line. These items are complicated and dealing with a guy who on minute is talking to someone about his tires and next about a New Issue NAV system that even if you own it, still keeps you head spinning.
They could do better.
Great Cars though.
Discussion Starter · #10 ·
The Failed Notification.
99 percent of the time I have my phone with me. So the fail box is a good reminder to me that I have forgotten my phone, Stop the Car and go back and get it. :) I guess the lesser of two evils.
I only notice that box when I went out to test it but wasn't going anywhere so I left my phone in the house.
Discussion Starter · #11 ·
Now I just want to know how to get my IPhone to display the text messages on the screen. Anyone know the answer or what kinds of phones will do this?
Apparently IPhone's don't have the right format.
2013 OB 3.6R Limited, Black Silica
You are incorrect, my iphone 5 will display my texts on screen as well as read them back to me.
There is a thread here somewhere that I followed to get it working but it is a setting in the iphone, something about banner type. You'll have to search but the answer is here somewhere.
I couldn't find the thread either, but here are the steps on your iPhone5:
1. Settings - Bluetooth
2. click on CAR MULTIMEDIA
3. turn "Show Notifications" ON
4. also turn on "Sync Contacts" if you wish
That's it, I believe. Worked for me.
Edit: But the REPLY function doesn't work on the car. Another Subaru "feature" that is broken
Edit2: I almost forgot, you also have to make sure messaging is turned on in the car. Just press the "phone" icon on the left side of the screen and turn the three messaging switches on
Not to hijack your thread but has anyone seen directions/turn list not fully displayed? This picture shows my turn list but I obviously can't see the names of the road or highways. It shouldn't look like this, right?!
Also, will anyone with Sirius let me know if they see three lines of data on their display? I only see two but only when using Sirius - I see three in every other mode. Driving me crazy...
2013 Outback 2.5i Limited w/ Eyesight (Graphite Grey)
I believe you should only see two lines in XM because they do not broadcast the album portion of the song tag. I have never seen album information displayed on any XM device before. Has anyone else?
You see three lines elsewhere because of the ID3 tags (which include album information).
Regarding your display looking greyed out, that usually happens when you are driving. It doesn't want you focusing on the screen so it greys everything out. I will verify this after work today.
2005 3.0 R n totaled
When I get a text message on my Samsung Galaxy SIII audio alert is heard and the text mesage is read to me (text-to-voice feature) by the NAV unit, after I give OK on NAV screen display....and that is by "default" - I haven't set it up that way....
I agree about the album info - I don't think they post it. But on stations that play music from concerts - Grateful Dead, Pearl Jam, Jam On - they include the date/location. I've seen it in other cars and devices with XM but nothing on my car. I thought I could find something in settings or ways to toggle the display but no luck. Do any listeners of those stations have feedback?
If the directions are supposed to be blank for safety's sake then I'm speechless...
I checked and yep, the directions are only fully displayed when the car is stopped. So if I'm driving on the highway and want to see where to exit in 20 miles I can't find out until the nav tells me so or I stop. Makes perfect sense.
update: while turning off trip log does improve the lag issue - I'm pretty sure there is a memory leak of sort when playing iphone/ipod music - the nav gets slower and slower as time goes on - I end up unplugging and replugging my iphone to clear that but it's very annoying. not as annoying as "traffic jam ahead" audio spam but close
I agree hiding the highway / street names while driving in the route directions is also completely stupid - so is the fact that even if I have a passenger they can't use the unit (the car knows there is a passenger (airbag sign etc...) so why not unlock the nav then... or just let me take my responsibility - isn't the annoying "I agree" each start enough...)
Discussion Starter · #20 ·
Your right, I don't think there are many children driving a 2013 outback with Nav. I can be an adult and don't need to have it disabled. I drove 3000 miles with a friend when I bought it and we could not really use the NAV when we were driving. Even though he was using trying to use it as the passenger, it was really stupid and useless. I agree.
1 - 20 of 20 Posts
