Adding tweeties used to be the first choice(cheap&easy) but I think the '13 base now has them. There is also a factory Subwoofer available that goes under the drivers seat.
IIRC the 2011,12 and 13 all have different wiring harnesses to the HU and steering wheel. I think they changed manufacturers in there somewhere also.Thanks for those responses. I need to clarify my question.
I'm not looking to upgrade as in better sound. I was curious if any of the other Factory Head Units will swap into my 2013 Premium or is the wiring in the 2013 base Premium not compatible with 2011 or 2012 or 2013 other factory HU?
That's what my research has been impying, I was looking for a definitive answer. I guess I'll pull my stock non-HK unit and take a picture of the back and compare that to the HK 2012 (non-nav) units that seem to be readily available all over the net.IIRC the 2011,12 and 13 all have different wiring harnesses to the HU and steering wheel. I think they changed manufacturers in there somewhere also.
Again from memory, I can't recall any Gen4 HU that will allow two phones active at the same time. Last one synced is active......My goal is to get unit that syncs to 2 phones simultaneously. I only listen to news radio so I don't need improved sound, just a real good bluetooth interface and bluetooth sound and mic quality.
So my question, is then is the pairing information for the second phone still stored and I can manually swap on the fly or is the paring information for the second phone lost? On my phone only one phone's pairing information can be stored.Again from memory, I can't recall any Gen4 HU that will allow two phones active at the same time. Last one synced is active.
