2011,premium,2.5
Think this could be done if I use an aftemarket radio? I could see the whole plate might not fit right but the buttons....maybe? Reading about some ones post on pin harness layout it's the same as pin 14 think this could be done?
Maybe... The wiring from the '10 and '11 is different from the '12 and '13 but the harness for the controls inside the wheel may be the same. All you would need to do is to pull the switches and maybe the airbag to verify the wiring at the controls is the same. Once you get that far the only other thing that you would have to do is verify that you have the sma two or three wires behind the radio.
2011,premium,2.5
I didn't know they have this in 2011 models but looks to me like it was in ones with nav/sat,will be looking into it more when I get my radio installed and such, found a unit that should let me use all steering control (answer and hang up) for 70ish...not money I want to spend plus the board and new cover plate on the steering wheel
