1 - 9 of 9 Posts
2008 Subaru Outback 2.5i-Auto. 2013 Subaru Outback 2.5i CVT Premium, Cypress Green
Will a 17" OEM Subaru wheel from a 2008 Outback also fit a 2013 Outback?
I have a 2008 and 2013 Outback and a full size spare in the 2008. I'd like to switch it from vehicle to vehicle for road trips. I know the tire itself is a different size.
Several threads on this forum have covered the fact that the generation 4 sparewell will not accomadate the 225-60-17 tire, even aired down. But if the wheels will swap I would at least be able to use a 225-55-17 new tire from 2008. Even though shorter (26.7" OD v. 27.6" OD of the 2013) it would still be a better second choice than mounting the donut spare or carrying a spare of 225-60-17 laying openly in the trunk or in a roof basket in case I destroyed a tire 100 miles into the forest. It would be temporary until a tire shop could be found, not a fifth tire for rotation.
I has wagons.
Yes, it will fit.
Thanks for the response. One less thing to worry about. Oh wait...should I worry about brake clearance issues?
2010 OBW limited 2.5 CVT
No issues for brakes. You could put 16" wheels on the 2.5 cars. The 3.6 cars require the 17" wheels.
Thanks guys! Now I can sleep tonight. Tomorrow the 2008 wheel/tire goes in the 2013 sparewell. you've saved me the trouble of jacking up the 2013, removing a wheel and seeing it fit for myself.
I'm not sure if this is relevant (based on your 2008 comment), but on my 2012 subaru outback 2.5i premium, a full-size 17" spare (and I bought the *same* tire as is on my Subaru), DOES NOT fit in the spare compartment *even* with the foam insert removed.
My solution: master lock python cable secured to overhead child seat lock allows me to store tire vertically (takes up a lot of space laid horizontally).
I have a 2013 CVT Outback. Simply pulled out the donut tire, put in a full size spare with all my gear under it and in it. It is perhaps 1/4" high in the middle, but the back and front lie down. No real difficulty. Tire is fully pressurized and on a OEM Subaru 2010+ rim. Not a perfect fit, but definitely cheaper than buying a $500 cargo box or basket and the resulting increased gas mileage. I could have driven it down the 1/4" at the front if I wanted with a rubber mallet, but saw no need to. The fit is actually alright. Then in the bed I carry Treds for sand and mud extrication, a small compressor and a come-along (which is marginal at best).
13 Outback 2.5i Premium w/AWP 6MT
Only thing is your tire size might be different.
1 - 9 of 9 Posts
