1 - 8 of 8 Posts
I have a 2014 2.5 limited wheels 225/60 r17 with the offset being 48mm. It has just normal stock highway tires on it now from the dealership. I got a 2" lift put on and want to switch to the Falken WildPeak a/t but I keep seeing people having a 35mm offset. I am trying to figure out if spacers would help? Do I need to be concerned with the tires rubbing? What do I need to do to make sure they fit without changing rims?
2020 Onyx
The Wildpeak A/T Trail comes in 225/60 r17 and will fit on your rims without rubbing just the way your all-seasons do.
I ended up finding a set of 16's off an older outback that fit. Looking at either 235/70 or 245/70. I do believe the offset will be the same though. Just needing to know how close I will be to the strut guard. If I'm going to need a 0.25 spacer or if I'll be able to get away without one.
2020 Onyx
First, make sure that the bolt pattern is correct. If it's 5x100 (2014) vs 5x114.3 (2016) they are not compatible.
For offset use this: Wheel Offset Calculator
1 - 8 of 8 Posts
