2015 Subaru Outback 3.6; 2015 A7
Hello all
Our 2015 3.6R with 25K miles revs between 600-800rpm if we are stopped on a red light (i.e. in drive with brake pressed). Noticed that if I turn the AC off then it does not fluctuate the rpms.
The only thing I did last week was to replace the OEM battery with a Bosch battery (group 25).
Has anyone else seen this before?
Link to see video: https://we.tl/WFedtfx8mM
thanks.
The fluctuation may be as the AC compressor kicks on and off? Higher RPMs when the compressor is engaged, lower RPMs when it's not engaged?
Banned
Hello all
thanks.
I think if you do some searching there is already a thread on this with a zillion posts.
My '15 2.5 does it. I haven't never given it a second thought.
2013 Outback 2.5i Convenience
Perfectly normal. AC puts a load on the electrical system and the ECU adjusts for it by increasing the rpm momentarily. Same with the radiator fans when they click on and off.
I've noticed an irregular idle after battery changes; seems like when there's zero power the engine has to learn the optimal idle again?
