No, Fujitsu sends head units without SD cards.If the dealer replaces the Fujitsu head unit does it come with an updated sd map card? Second question is does it come with the firmware/software already updated?
Thanks for the info.No, Fujitsu sends head units without SD cards.
Dealer puts current into new headunit and registers new head unit with XM/Sirius.
Customers are required to update their own cards.
Exchange units from Fujitsu/Clarion/etc should have updated software when they arrive at dealers, but dealers can quickly scan and check that during swap out for you.
Are you saying that the problems started when the dealer tried to update the head unit firmware? (If so, you didn't state that previously.) The dealer (or you) can easily confirm the firmware revision levels currently installed in your head unit. Look at the next to last step (Step 5, page 19) in the instructions from TSB 15-205-16. From the symptoms you describe, it sounds like the firmware from USB Drive 2 failed to install correctly. If you're at all competent technically, you can easily do it yourself; there is an entire thread on this forum devoted to the topic.My dealer wants to change out the head unit and i believe they just have not completed the update properly as the navigation and turn displays no longer show up on the dash display. All that I read online indicates the 2nd part of the update did not install correctly. After two attempts he mentioned that the next step is to change the head unit ...
