2016 Outback 2.5i Limited
Hi. 2016 Outback 2.5i limited. Had it for almost one year since 2016 with ~ 9000 miles. About two month ago, I started to notice rhythmic noise when turning the steering wheel. Sent it to the dealership. Was told that the steering wheel was a little bit off the right position and the rhythmic noise problem was solved. However, soon after that, I started to hear click noise when turning the steering wheel with the turn signal on. About 2 clicks with a full turn. The click noise is there no matter turning left or right. Note that there is no click noise if the turn signal is off. Any of you have the same problem?
PS. It is not the turn signal sound.
