2016 outback engine vibration
1256 2
my 2016 Outback engine vibrates when stopped at the traffic light or when parked with the engine on.Was at the dealer four times already they did ECM update and the fuel test, vehicle failed the test I have been using higher branded fuel without any improvement. Does anyone have any suggestions?
Meh.
I has wagons.
This is why warranties exist. Keep taking it to dealer until they fix it.
Reactions: z28dug
2016 Subaru Outback 2.5i Limited / OP: 23 / PP: 5
Did you get your issue fixed? Mine vibrates quite a bit too, but only when in Drive with the A/C running. Push the A/C button to turn off the air...and it quits. Almost acts like the idle is too low for the load.
