When it got cold here the rear lift will not work. The lift raises about a foot. Sometimes makes a loud horrible almost like banging sound. Then stops. Sometimes it closes. Other times it just hangs. Is it the struts causing resistance ? Ideas ?
The horrible almost banging noise sounds more like a binding motor or gear assembly in the lift mechanism.
Its an easy replacement if you can get access to a wrecked subie of the same generation as yours.
