My first post here, though I've been lurking for several months since we got our Outback last fall.
Not having CarPlay has bugged me since we got it and after months of use I found the nav system to be a sub-par experience. I knew I'd be upgrading the infotainment system sooner rather than later. I found some great information in threads on here, and thought I'd post my upgrade experience to help out a bit if I can. I'll probably miss a few details in here, but I suppose this isn't meant to be a detailed installation guide.
Bottom line: I'm really pleased with this installation, and would enthusiastically recommend it!
Here's what I went with:
). As it turns out, the wiring colours match up, but I wouldn't take the chance and just make that assumption out of the gate.
The trim panel pop off with a bit of encouragement - I was afraid I'd break a clip, but everything went fine. Tip: you don't need to remove the bezel around the climate control dials, just the bottom trim piece. Once you get the trim out, everything comes out very easily. Reassembly is very simple, and once the vent piece on top and the climate control unit are clipped into the Metra faceplate, you can pop the entire thing out as one giant piece. My HU is recessed in the faceplate, which could probably be adjusted with some judicious trimming and adjustment of the mounts, but I'm happy with it (for now, anyway).
Things are generally well-coded with colour. Once you've figured out which bit goes where, you need to splice some bare wires. as these are low-strain connections, I just twisted them and sealed with heat-shrink. There are several wires on the Pioneer harness, and two on the iDataLink harness which do not get used - I HIGHLY recommend you tape the ends up on all of these, as even without the end being stripped (i.e. insulation to the end of the wire) on reassembly a wire ended up touching the radio chassis and I was getting an "AMP ERROR" code. Once I took it apart again and taped the ends up, it was back in business.
Cable Routing:
Things I'm not sure about:
- Pioneer DMH-2660NEX (wanted the capacitive touchscreen; I find the resistive ones to be a frustrating user experience)
- iDataLink Maestro RR
- SU-2 wiring harness
- Metra 95-8906HG dash kit/faceplate
Cable Routing:
- iDataLink module is tucked in the dash above the glove box - lots of room for it there (black circle in one of the pics below).
- I ran the mic up to the driver's top corner of the windshield (where the oil change sticker is normally placed). Ran the cable down the A pillar, under the dash and into the back so it's completely hidden.
- I ran the USB cable down the driver's side of the console and by the seat belt latch. It's completely hidden, but not tidy at the end by the seatbelt. I may try to install it in the metra faceplate or the trim piece to the left of the console cubby which can pop off and has some space.
- I plugged in a longer USB cable for the iDataLink module, and ran it down the passenger side of the console. The end is just tucked up behind the console panel. I did this so that any time I want to do something with the module (reflash) I don't need to take the dash apart. As I'm typing this, I do wonder if this is safe to do with everything plugged in (car turned off, obviously)? Something to look into....
- Antenna connection: There was a blue and a grey antenna connection in the dash. I didn't have the factory wiring diagram with me, so plugged in the grey one. Radio reception works, but it was not bad even without the connection so I'm not 100% sure I plugged it into the right one.
- iDataLink flashing: I left pretty much the default values. My radio preset +/- goes up/down by frequency step, not preset. Will need to look into this.
- iDataLink controls: I don't have access to the climate controls on the Pioneer unit, nor tire pressures, and the gauges screen doesn't function exactly as I expected. None of these are deal-breakers by any stretch - this upgrade was for CarPlay and Google Maps while driving, with the other functions as nice-to-haves. I'm not sure if I've missed a wiring connection somewhere (my Starlink wire is not connected, nor a couple of others, as I wasn't certain about the connections, and primary functionality is not affected).
