If possible, I'm looking for 017 Lift gate lights or other solution?
I've found the back turn area to be a little dark on my 2017 so looking to add a bit of brightness to it.
Thank you for any suggestions or insights.
Sent from my SM-G930T using Tapatalk
2017 Outback Premium 2nd Subaru owned
I changed to the brightest led plug in with the strip. offered by Diode Dynamics. I am very pleased with the brightness. It did take a while to get the led contacts to properly touch.
I have also added a round led battery operated light prior to the led conversion. It has a push button switch in the center of the light. That I have mounted on the inside of the tailgate. It is centered below the glass . That provides extra light if rarely needed.
Tapatalk sucks at hotlinks. Search for rear aftermarket hatch light on the 5th gen forum. Pretty much someone put an led panel from a Forester in that removable panel on that hatch that gives you access to the latch. I did this mod on my 2015 and plan to do it on my 2018. Works super well if you're not afraid to do some wire splicing.
Sent from my Pixel using Tapatalk
