2017 OB climate control
5232 12
My OB premium 2.5 has the type B dual climate control. Full Auto seems to be the preferred setting but the fan really blasts full on especially if the cabin is hot after sitting in the sun. Lowering the fan speed causes the system to revert to Auto. What the manual fails to explain is what, if anything, is being controlled "automatically"? Ideally I would like to have the Full Auto temperature control allow for fan speed control but in lieu of that, I guess I can go manual (with a less annoying fan speed) until the cabin cools down and then let the Full Auto take over.
1 - 13 of 13 Posts
If you understand the manual's explanation Auto is Auto. Just let it handle it or do it manually that is your choice.
:welcome: [emoji482][emoji482][emoji482][emoji482][emoji482][emoji482]
Fill out your Profile and have Fun![emoji477]
Laughing at Oneself and with Others is Good for the Soul[emoji16]
So what's the difference between Auto and Full Auto?
Full Auto (Auto Button) start high, it cools the cabin then the fan decrease once it get to the designated temperature. Once you manually alter it then you changed it to manual A/C and no longer in Auto mode.
You are confusing Auto where the compressor forces cool air( let call it engage just for ease of understanding) to temperature set then ?disengaged? the compressor without temporary lower temperature and increasing fan speed.(Auto) Auto Button is just automatically is in control a lot like a home Auto heat pump.
2016 Outback 2.5i Premium
FULL AUTO means the system controls everything. If you make a manual adjustment then it will revert to plain AUTO. When it's in AUTO, it's still controlling everything except the setting(s) that you manually adjusted.
@ammcinnis clarified this for me a while ago. I'm in Florida and prefer to have recirculation always on. I set my AC to FULL AUTO and enable recirculation manually, which puts it in AUTO. Now my Outback manages fan zones, speeds, etc. but doesn't manage recirculation.
FULL AUTO means the system controls everything ... When it's in AUTO, it's still controlling everything except the setting(s) that you manually adjusted.
You said it better than I.
1 - 13 of 13 Posts
