Title says it all. What is the best LED fog light for the Outback that matches the OEM HID lights? I'm looking to rid myself of the discrepant lighting. While I'm at it, reverse lights, too?
It’s a 921 bulb. The instructions to replace can be found in your owners manual. Basically pop the panel off the hatch, twist the bulb hold to remove and pull bulb out. Reverse to install.Canisreevus:
I have a 2018 Outback Limited and noticed you have an 18 Touring. I want to put in LED Bulbs for Backup lights. I think the base of the bulb has changed to a 7440 type. Could you confirm that? It makes a difference with what I order. Also not quite sure how to replace. It appears there are two snap panels in the Hatch Back and the socket just twists out. Its been too cold too explore.
Could you explain how those bulbs come out?
This would help greatly. Many thanks.
