Air in the system makes the pedal feel spongy. The pedal should move, but start to feel firm. Spongy is not firm. If it's spongy, do what everyone else said and change out the fluid. Spongy is not drop to the floor either. Spongy will feel give you feedback, but not continue to sink.
With the car idling, press the brake pedal. It should start to move downward then become firm. If it starts to move downward after this point with any force you care to apply, then either the master cylinder is bad or the ABS dump valve in the ABS pump unit is stuck open. To diagnose which problem it's experiencing, a more subtle test is required that you may or may not be able to interpret the results of since some prior experience helps a lot.
The ABS dump valve is essentially a larger "leak" than a worn master cylinder. The ABS dump valve will cause the pedal to drop faster, but once the pedal is quite low, it will become firm and brake well. With the master cylinder issue, the pedal will eventually bleed out all of the pressure and head towards the floor/pedal travel limit.
If it's a worn master cylinder, it will need to be replaced. If it's a bad ABS dump valve, the pump will need to be replaced or rebuilt (not necessarily the electronics, but a dealer won't seperate the two). ABS pumps can fail early if brake fluid is allowed to get contaminated.
"but he said everything checked out good "
What an odd thing to say...He just said the brake pedal was low!
