Nice choice!I gave up the battery drama with dealerships (willful or incompetent?) falsely declaring weak batteries "good" and bought an Enersys/Odyssey group 47 (fingers crossed that they'll actually ship it).
Are you saying that you fully charge your battery on an external charger, then after being off the charger overnight, see 12.0 volts the next day via the dealer mode display with the car on/engine off?I mention that I saw 12V fully charged after sitting overnight to stress there wasn’t any unusual drop overnight, which to me says a good electrical system with no unusual drain and a good battery that holds its charge, even though it’s only 12V and not something higher that we might be used to seeing on cars in the past.
<snip>
BTW, all my voltage readings are taken directly from the car’s electrical system using the signal option in dealer mode.
No external charger. I drove it two hours showing 14.1-14.2V the whole time, parked it overnight, the next day saw 12.0V with the engine running via dealer mode. After a few minutes it went up to 14.8-14.9 momentarily, down to 14.1-14.2 for less than a minute, then back down to 12.0 for several minutes. To me that's a fully charged battery because it mirrors the charging pattern I see on my truck with an AGM, other than the absolute values being a few tenths different one way or the other. I have not done an independent multimeter check of the voltage and am taking the dash display at face value. Bottom line is I'm not having issues with our Subaru battery, and have seen off cycles using start stop for as long as 90 seconds. Works for me.Are you saying that you fully charge your battery on an external charger, then after being off the charger overnight, see 12.0 volts the next day via the dealer mode display with the car on/engine off?
Using an external charger to fully charge the 620 EFB, I leave it overnight, open the door, pop the hood, get a reading (and the car is not on but it's awake) and was getting around 12.3 volts until I did a reconditioning cycle then I would get closer to 12.47 or something.
What bothers me is when my dealer claimed 12.68 volts then I drive 5 miles home and pop the hood an hour later and get 12.33. I will post the results of my AGM battery experiment and we shall see if an AGM performs the same way or not. It could be a complete waste of money but a worthy experiment and I'll faithfully report my findings.
An impressive battery. It will be interestiing to see how it works out compared to the one I have my eye on at Autozone: Autozone AGM battery for OutbackOk I checked the website and apparently my order was cancelled without telling me (I logged on to the website to check my order status). Am awaiting follow-up for an explanation. Meanwhile Napa is showing the Enersys/Odyssey batteries now. So the battery experiment is on hold for now until I can figure out how to get one. None of my NAPA stores have it in stock locally so I'll have to contact them by phone to find out if I can get it without paying a hundred bucks for shipping.
How do I access this dealer mode so I can watch voltages when I get my car backNo external charger. I drove it two hours showing 14.1-14.2V the whole time, parked it overnight, the next day saw 12.0V with the engine running via dealer mode. After a few minutes it went up to 14.8-14.9 momentarily, down to 14.1-14.2 for less than a minute, then back down to 12.0 for several minutes. To me that's a fully charged battery because it mirrors the charging pattern I see on my truck with an AGM, other than the absolute values being a few tenths different one way or the other. I have not done an independent multimeter check of the voltage and am taking the dash display at face value. Bottom line is I'm not having issues with our Subaru battery, and have seen off cycles using start stop for as long as 90 seconds. Works for me.
It's important to note this is different from the old Subaru charging cycle that would arbitrarily drop to 12V when the battery wasn't fully charged. It took 2+ hours of steady driving and constant charging at 14.1V before the voltage finally dropped to 12, which happened to be on the next day after sitting overnight. If there was some sort of dark current drain or battery deficiency, it certainly wouldn't still have had a full charge in the morning. Is 12.0V lower than we might be used to seeing from a fully charged battery? Perhaps, but it's working fine, and the 11.7-11.8 voltages I am seeing during start stop cycles matches what others have reported, so I can only conclude these are accurate numbers.
Hold the two passenger temperature buttons (blue and red arrows) down together and press the radio tune button above them six times fairly rapidly. Beware: there are a lot of things you can mess up in dealer mode, so if you're not sure about a setting in there don't mess with it. Dealer mode is what a bunch of us learned back in June when the first big software update came out; the software update screen is at the bottom of the menu. There is also a screen that gives more details on different subsets of software in the vehicle. The voltage is in the "signal" menu about halfway down. To return to normal, just hit the back button near the top left, then the home button that appears at the bottom of the display. Suggestion: you can access dealer mode in accessory, on without ignition, or on with engine running. If you're going to experiment I'd just sit in the driveway and try it with the engine off using accessory mode (hit the start button one time without pressing the brake pedal; yes, some people don't know how to get into accessory mode). Don't crash if you try dealer mode while driving; everything still works normally, you're just viewing a screen that is intended for diagnostics, not something you would normally be looking at while going down the road.How do I access this dealer mode so I can watch voltages when I get my car back
Press down both red and blue temperature control arrows at the same time then press either the volume or tuning button six times consecutively (on the same side of the red and blue arrows).How do I access this dealer mode so I can watch voltages when I get my car back
You may want to consider installing a SAE 2Pin Ring Terminal Battery Cord Tender Cable Harness Wire Plug Quick Connect. I have the Battery Tender version with extension to get access at the grill without waking anything. It could also be placed below the grill. This black connector is not easily seen unless you are looking for it. I can easily access the battery for voltage measurements or charging. The plug has a weather cover to keep it clean and dry. I use a little silicone grease to help keep the connection points hydrophobic/dry.Using an external charger to fully charge the 620 EFB, I leave it overnight, open the door, pop the hood, get a reading (and the car is not on but it's awake) and was getting around 12.3 volts until I did a reconditioning cycle then I would get closer to 12.47 or something.
If I have to battery tend my vehicle every night, I’m not going to be happy and will let my battery die every night and start having it towed to the dealer every morning on their dime and have them jump start it.You may want to consider installing a SAE 2Pin Ring Terminal Battery Cord Tender Cable Harness Wire Plug Quick Connect. I have the Battery Tender version with extension to get access at the grill without waking anything. It could also be placed below the grill. This black connector is not easily seen unless you are looking for it. I can easily access the battery for voltage measurements or charging. The plug has a weather cover to keep it clean and dry. I use a little silicone grease to help keep the connection points hydrophobic/dry.
View attachment 501115 View attachment 501116
[/QU
The suggestion was directed to SilverOnyx and was not intended to advocate the use of a Battery Tender. IMy comment simply provides a method to measure the battery voltage without the process of opening the door and hood. Sorry if this was not made clear.
If I do it on the tuning side it usually unsyncs the temperature settings. Better for me to use the driver's side control arrows.Press down both red and blue temperature control arrows at the same time then press either the volume or tuning button six times consecutively (on the same side of the red and blue arrows).
Someone else did a Lithium battery and seemed pleased with it but to me it's still too esoteric - the charging system may need modification. He bought his Lithium battery from China and it was way cheaper than AntiGravity.I’m curious about a Lead Acid replacement for an ASE Outback, instead of an AGM. Just curious.
What about LiFeOH (Lithium Iron Phosphate) ones? I think I read that those are popular in EV’s because of discharge duties.
