This was part of the discussion in the 19mm Gen5 and then later the 20mm gen5 sway bar threads. Those are long threads to read through.
since the 20mm is a bit stiff for your driving area (and that’s what‘s really important) - the 19 might be a good choice. There is also an 18 available. I think I found an OE 17 that fits.
For percentages, you should look at how much more stiff it is vs your OE 16mm, I wouldn’t compare the 19 vs the 20 difference only. Different perspective when you look at the numbers. All that stuff was also in those long threads back when.
It might be cheaper to get the 19mm perrin adjustable, which could be the equivalent of the 20 you tried, the 19, and an 18. It’s not terribly expensive. If you can find a good deal on a 19, I’d say try it out. I’d like to try a 19. Or even an 18. It’s not urgent though.
for some of the driving/loads I carry, the 20 was annoying enough that it wasn’t worth it over when you’re just driving around on smooth roads. Reminded me of a solid rear axle, like my old pickup truck in the same situations. I took a chance on the 20 because of the price at the time, and that didn’t work out. It’s still hanging on the garage wall - I really should sell it.
