So my 2014 OB is out of warrantee and I plan to do some upgrades starting with tires. I think I am going to order a set of Geolander 225/65R17's but I am not sure one will fit in the spare tire area. Is there any permanent damage I could cause if I had to use the smaller tire to get to a place to by a replacement tire? I realize it may not handle as well and could mess with the AWD with mismatched tires...
2012 Outback Ltd 3.6r
Have you checked the current spare? - It isn't even close to 225/60R17, it's a tiny little temporary spare. which is why it needs to be placed on the back. (If you have a flat front, you need to move a tire from the back to the front, and then put the spare in place of the back tire.
Even the stock 225/60R17 doesn't fit in the spare well, not inflated anyway. Supposedly international Outbacks *might* have a larger spare well, but cannot confirm.
The system is designed to allow a smaller tire on the back end for short periods of time. You should be using that spare for speeds over 50, or for distances of 50 miles anyway.
Supporting Vendor
Tire & Wheel Specialists
PM coming your way.
