Check your sizes.<o
OEM 225/60R17 27.62”OD 60mph<o
Optional should be:<o
245/55R17 27.61”OD 60.0mph<o
245/50R18 27.64”OD 59.9mph<o
<o
What offset wheels are you looking at?<o![]()
I'm not too worried about the actual tire yet, I'll do research on the prior to purchase. For actual 4X4ing we'll have my FJ. The OB is a go to Yosemite in light snow and drive through some pot holes that have flooded. No trails etc. I'm concerned with mostly fitment of the tires and clearance of the wider section.i think you can get your speedometer recalibrated when you get an alignment. mine is off by just a bit so i'm not too worried about it. when i get bigger tires ill recalibrate it. if you just want to get through snow and dirt/rain, you should be fine with just about anything. just don't forget to turn off the traction control if you have issues.
