1 - 20 of 21 Posts
2019 Subaru Outback Limited 2.5i
Other than a slight negative camber / wear on my front tires, no issues yet and I’m already at 26K miles.
Changing the oil / filter religiously every 6K. Installed the Fumoto valve - works great / no oil spill.
Averaging 28mpg city/highway, 34mpg highway with the 2.5L
So far, very happy with my ‘19 OB Limited. Anybody having any issues / problems with their '18 or '19 OB? Comments, pro or con, please post.
Read Only
2011 outback 3.6R LT. 2015 Outback 2.5 (white) eyesight, tow pakage, skid plate, moon roof
So far, very happy with my ‘19 OB Limited. Anybody else with comments, pro or con, please post.
I get 24mpg city and 29mpg highway with 64 K, Drive between Reno , NV Phoenix , AZ and cedar City,Utah
2016 Outback Limited Titanium
I’m at 15K miles on my 2019 OB Ltd with 2.5 engine. I’m currently on a 2K mile road trip from my home in CT to Louisiana and back. So far, running great averaging about 30 mpg in mostly interstate travel. Do plan some non-technical off roading this weekend. Subaru Outback for me is the ideal “Vehicle-Assisted-Exploration” vehicle.
My '19 premium only has 3500 miles but everything works just as it should.
Thanks for your note - my highway mpg drops to 29mpg when driving between Reno and SLC - 80mph on cruise control.
Thanks for your note - I refer to my OB as a "Snow-Ski Machine".....
2018 Touring 3.6R
36k miles on our '18. Head unit died out of the blue around 6 months/12k miles but new one has been trouble free. Rear seat bottom had the leather replaced due to a funky spot. Otherwise no issues besides some rattles in the cabin. Averaging about 26 mostly highway. Tires are 7/32nds and wearing even but getting noisy.
2017 Outback, 2.5L, Auto; 2018 Forester, 2.5L, Auto (for Mama); 2005 Baja, 2.5 Turbo, Manual
You might want to check the toe in. Toe will wear inside tire edges (or outsides) much quicker than camber. And se a real alignment shop rather than the dealer, an old guy who will take the trouble to center the steering wheel after setting toe.
Discussion Starter · #10 · (Edited)
Do you have the 2.5L or the 3.6L? In the city, the 2.5L is rated at 25mpg, while the 3.6L is rated at 20mpg - I suspect you have the larger engine.
My biggest problem so far has been the mpg gauge that showed 5% high. Everybody’s mpg gauge is high before they get it fixed. See my signature line.
Discussion Starter · #12 ·
Thanks for the tip - I’ll double-check the accuracy on my next fillup...S
I have a 19 2.5 premium. Been great, only issues I've had is a battery that had corrosion and replaced under warranty with a larger battery and rail dust that needs to be removed every 6 months (very obvious on white).
One problem I've had is getting lots of door dings. I have 4 big door dings and one in my hatch where it looks like a truck hitch hit it. Going to take it to pdr place this spring.
I've got a new to me 2018 Touring 2.5 with 19K on it and am getting 24.36 hwy avg (hilly upstate NY highway)
Fuel is an actual calculation of miles/gallons at the pump... my meter is close..within 2 tenths. I suspect it has been adjusted.
I did manage to get the meter to show 27.9 being super light on the gas pedal.
Service records show that the head unit was replaced as was the battery before my purchase at almost 18K.
I have a 2.5, so was expecting a bit better city mileage...honestly not super knowledgable about mechanics of engines, so just wondered if it was something I should be concerned about or just the way I drive/idle
The Subaru Outback is pretty big and heavy. Even if my 2.5 were to average 24 mpg, I would consider that pretty good. Last time I checked my average is 26.9 mpg, mostly city driving.
Discussion Starter · #18 ·
There’s another Head Unit replacement in this thread and I’m also surprised to see another battery replacement, given just 2+ years old. 27.9mpg combined sounds good...thanks for your note. Scott
if you search, there is a long thread about each of those topics... the 2018 head unit (different hardware revision than yours BTW).. resolved for the early problems, but there was a time where the fix was to replace the head unit... and there is another long thread about replacing the OEM battery with a better one (I think that's the title - close enough). The OEM battery doesn't seem to be the best quality.
1 - 20 of 21 Posts
