1 - 8 of 8 Posts
2000 Outback
Hi, lost a belt today and the bottom pulley does not move even when a/c is on (currently no belt).
Is this the norm?
Thanks much.
Is this the norm?
You'll have to be more clear - do you mean the crankshaft pulley (C)? If so, the answer is yes, you are not going to turn it by hand with the belt removed. Everything else should spin freely, though.
474205
Brucey
'17 3.6
I think that's an EZ30D or something. It only has one belt. The EJ251 in all 2000 Outbacks had two belts.
It's also possible the user is talking about the tensioner for the AC belt. I've had those seize up before.
OK, 2.5i serpentine belt image below. The bottom pulley is, of course, still the crankshaft, and it won't turn by hand. The middle pulley is the idler and it should spin freely.
474215
2000 Outback
Thanks all, trying to make sure it's not frozen to waste time $ and a belt.
Flooded out here and just getting back to Subaru now, sorry for delay.
2000 Outback
Yes, it's that one!
Is it supposed to be free moving when no belt is attached?
2000 Outback
Discussion Starter #8
Thanks much everyone, looks like it's time to go buy an Idler Pulley.
1 - 8 of 8 Posts
