1 - 9 of 9 Posts
2001 Outback 2.5, 2015 Outback w/ Eyesight
My 01 Outback made it all the way to 196,000 miles before I had to get a mechanic to replace HGs. However, I only made it 36,000 this time and it looks like drivers side HG has failed again. Why are not these HGs holding up? I guess I will replace it this time myself. What are the best gaskets made out there? I do not want to do it again after this.
Meh.
I has wagons.
+1 on a sloppy job.
Were the heads checked and resurfaced if needed?
What type of HG were used, the single layer graphite of the failure prone original or the upgraded multi-layer steel style?
An engine that has not been severely overheated, that had a proper and careful job done with the correct parts is very unlikely to fail again.
If you want us to answer this question you also need to answer these:
1. what headgasket (brand and part number) did he use?
2. did he install Subaru's Coolant Conditioner - it's required in that motor?
3. were the heads resurfaced?
4. was Subaru's Coolant Conditioner added? (it is required by Subaru)
You can add a bottle or two of coolant conditioner right now if it's an external coolant leak.
Grossgary, I do not know the answer to any of these questions, it has been over 2 yrs and I trusted he would do the job right, but recently I am learning about these things. I wonder if I need to install new head bolts again when I change the gaskets. I heard that they are recommended. Also it looks like the drivers side is the only one leaking.
Meh.
I has wagons.
Replace both sides, safe insurance.
Head bolts are not torque to yield, so they can be reused.
1 - 9 of 9 Posts
