1 - 8 of 8 Posts
Hi Folks,
I have a 2011 Outback 3.6R with 110k miles. A couple of months ago (~2,000 miles?) it developed a noise from the engine that makes it sound like a diesel. Basically it's a soft "tick" (not a metallic one), or maybe more of a "chh chh chh" sound that is timed to engine speed. You can only hear it when stationary and at idle -- when the car gets moving the sound gets drowned out.
The noise developed over 2 or 3 days and probably just 100 miles, and hasn't changed since.
I've taken it to the dealer. They can't hear it while at the same time saying it's the injectors / it's normal. (Begs the question that if you can't hear it how do you know what it is...)
30 years ago I had an old car that had a similar sounding noise coming through the radio from the electrical system -- all it needed was a filter. This isn't that - this new noise is present with the radio off, and also with the climate control fan off.
We're in Colorado, run the regular 85 octane and I haven't tried anything else. Engine and transmission oil levels are fine, although the car is about due for an oil change.
Any ideas?
Thanks,
Toby.
the car will run briefly with the accessory belt off - try that.
'18 Outback Touring 3.6R, '11 Legacy 3.6R Limited. '11 WRX not stock
I would grab a length of heater hose or some tubing and CAREFULLY try to locate where in the engine compartment it's coming from.
2011 Subaru Outback 3.6r 5AT 260k km
Did you figure this out? Sound like what mines doing.
Ivin, 3 year old thread. But, the OP may get a notification and respond.
1 - 8 of 8 Posts
