bfoutch, thanks for posting this. I'm looking forward to ChrisJ's video, hoping to install the 19mm RSB on my OB soon.The attached pdf provides instructions and torque settings for the 19mm RSB upgrade. This and Chris' video should make installation easy and correct.
Just a note - no need to lift vehicle or remove anything other than the old RSB.
Thanks for catching the conversion error. Since my new bar had the paint marks, I lined the bushings up to the edges of the paint stripes like the instructions said and then used a 6mm Allen wrench to check the spacing to the stop. This worked out well for me. Also, I believe I recently saw that subaruonlineparts.com posted the instruction sheet in another post, so they should get the credit for the instruction sheet. I found it earlier on a legacy forum.bfoutch, thanks for posting this. I'm looking forward to ChrisJ's video, hoping to install the 19mm RSB on my OB soon.
Just one note for folks using bfoutch's pdf, the inch conversion is off, it states 6mm = 6.24in, when it's really 6mm = .24in. Looks like a typo in the Subaru instructions. The kgf-m to ft-lb conversions look correct. https://www.google.com/search?q=6mm+to+in
On a separate note, I've seen on the RSB thread that folks without torque wrenches hand-tighten as much as they can without stripping the bolts, and use threadlocker.... RSB Tutorial post322349 Is that really an acceptable method?
Bfoutch, thanks for recommending the torque wrench and loctite. I was a Lego Constructor/Builder in a previous life and working on (real, life-sized) cars is new to me. I never encountered a scenario where a particular torque setting was required, and in this application I decided to be prudent and followed your advice. I went out and got a beam style torque wrench from Sears, they apply the usual "bring it back and we'll replace it" warranty on these so I figured that was a good in-the-middle approach. You were right, I had no idea what kind of torque I was applying and I'm happy I got the wrench. I also had some loctite from a previous project: blue 243.Regarding torque. I was an aircraft mechanic in a previous life and consider proper torque as a requirement, especially if a torque is called out by the instructions. Just how would one tell when you are "close to stripping the bolts"? You will certainly know when you go past that point! Use a calibrated torque wrench and you do not have to worry about this problem. I also used blue Loctite 242 and torqued to instruction's numbers without any lubricant compensation. This is the method recommended by Loctite - "No on-torque adjustments needed". http://www.henkelna.com/us/content_data/168592_LT4985_Threadlocking_Guide.pdf
