95 Outback 2.2L/auto stone stock
Swings from about 500-1200 rpm at idle in park. Put the trans in gear (automatic) and you need to 2 foot it, and it still tends to die.
No trouble codes. Trans fluid level is fine, coolant level is fine, oil level is fine. New knock sensor. Revs up beautifully, but starts to stumble really bad if you let out of it. Plugs/wires have roughly 12K miles on them, air filter is a bit gray but seems to pass air through just fine.
Vacuum hoses are about 50% swapped out. I thought I heard a bit of a leak on the right side with it running this afternoon, front runner gasket area is disgusting, rear runner is spotless. Popped off the intake tube, throttle butterfly and intake manifold are pretty sooty.
EGR rod/piston whatever it is seems to move freely.
Going to spray around the gaskets and vacuum connections with it running, WD40 seems to work for anything else I test.
What else should I be checking? I thought plugged cat but, it revs great and there is a good amount of flow out the tailpipe.
California emissions legal car if it makes any difference.
does the car have cruise control? If it does follow the cable back to the servo and make sure it isn't dislodged, also not a bad idea to look at the pcv valve hoses, and brake booster for leaks.
Good, good and good.
I'll spray around the intake runner bases, throttle body and any vacuum ports this afternoon and see if I find a leak in any of them.
Would the OBD2 port give me any transmission codes, or is the 95 too old for a computer controlled transmission?
If the TB insides are sooty, then it is a good guess that the IACV is also sooty. Remove and clean thoroughly, making sure the valve rotates freely.
Use an impact screwdriver if you have, for those screws have a tendency to round.
No, you can't read tranny codes with an OBD scanner.
Do search for handshake method.
O.
