My transmission in my 96 just started leaking all over my exhaust, and when I went to check the gear oil level it was 2 qts low. I was wondering if there were any specific areas I should check to start off with.
Another thing - this transmission is not new, but new to me and so I have no idea the history of this transmission but I know it's at about 200k (my car is at exactly 250k) and my ol wagon won't start sometimes and instead just makes a buzzing sound for the first ~15 times you turn the key (it always eventually starts) AND for a third thing my clutch makes a ticking noise when I push in the pedal which makes me think throwout bearing but if anyone else more knowledgeable about these 5 speeds has another idea I'd love to hear it.
Please help me I certainly need it :20:
For sure check the drain plug, can come loose or sometimes needs a new crush washer or new plug in general.
The starter could be going bad, maybe your battery, could be a voltage problem.
A ticking noise when you push in the clutch could be throw out bearing, could be pressure plate teeth. They come loose over time.
Just my 2 cents, hopefully helps
