Thank the gov't for letting moonshine to be added to our gasoline supply. All the rubber and plastic parts of older cars' fuel systems will eventually rot away from this ethanol garbage that we now have to use. I have an 02 OBW with a fuel leak of it's own. Fortunately, the leak seems to seal itself once the engine has warmed up, but if you do a cold start in cold weather, don't run anything on the climate control unless it is on recirculate, or the gas fumes are bad enough to make me literally sick. I run the recirc button on warm up starts, but you can still faintly smell the gas. It's a really big issue for me, I'm afraid some of this "gasohol" will run onto a hot exhaust manifold and then....Contact your nearest political puppet and tell him or her that Everclear 190 is for people, not cars. To make it worse, lobbyists from the Midwest are pushing the ethanol to 15, and even 20 percent in the future. Pretty scary stuff.
