Hi all,
I've been replacing my clutch and transmission box on my '99 Outback. But the transmission (both new and old ones) will not slap up against the engine!
I've read everything there is to read about re-installing the MT on these OBs, and I've tried everything imaginable with NO RESULTS! See photo links below of input shaft, clutch plate and hole, and the gap that exists between the transmission and the engine.
Before you ask, here's what I know:
1. There's nothing blocking the tranny from hitting the engine anywhere.
2. The transmission is definitely the right size. Even the original won't shove back into it's place.
3. I have rotated the input shaft splines 10+ times and tried to shove it in, still won't go.
4. The transmission gets on all bolts, but not all the way up against the engine.
5. The clutch fork and bearing are all installed correctly and not interfering.
6. I have tried getting under the tranny and wiggling it up and down, left to right, a hundred times. No dice.
7. I have re-installed the clutch plate and disc three times, making sure it's facing the correct direction and aligned properly.
8. One of the lower bolts may be slightly bent, but the transmission still goes on all six bolts just fine. And if that one bolt is indeed bent, it's only a very slight, minute bend.
Anyone have any ideas on how to finally get this sucker on without breaking anything? I am losing my mind.
Here's the photo of the tranny and engine:
Photo of input shaft:
http://1.bp.blogspot.com/-k3F3pybq0PY/UVsHHpCdQuI/AAAAAAAAAgI/SianEr16zO0/s1600/input+shaft.JPG
Photo of clutch:
http://1.bp.blogspot.com/-0ElioWP9Tos/UVsHGbHsTQI/AAAAAAAAAgE/BObYjgo-a9o/s1600/clutch+hole.JPG
Photo of clutch:
