Hello all, this is my first time posting here
I am officially done with any form of mechanic on my car, all they have ever done is destroy my transmission and 2 engines. on the engine in my car it began to make a knocking sound so i turned the engine off and got it towed to the people who said they'd hold through on the warranty on my car since i had taken great care of the engine. i got it there and they declared, apparently without seeing the rods, that the rods were blown and it was rod knock, and going to cost $6300 to fix. screw that, they avoided the warranty issue completely by erasing all the times i came in to check it up. since it was on warranty i had no receipts from them. after telling them off saying id rather scrap it then let them touch any part of my car ever again, i decided to rebuild the engine. oh it blew just before 30,000 miles, with good care of the engine.
the car has had the transmission rebuilt about 30,300 miles ago
I am a noob to this,
I am in school for physics, after changing from mechanical engineering.
i haven't been working on my car because ive been too busy, now that my car won't work it is bering only a hastle.
i do believe that i possess the capability to do this and it is not scaring me away at all. but first i need to make sure i have a good understanding of the process. thats why i'm posting now.
I need to order a rebuild kit and want to make sure that i order the right one. the engine came completely stock as far as i know. the link below is to a kit i want to make sure i could use and if i would need any of those options. i can take things apart and put em back together with new parts but finding which parts are the right ones is my hard part.
Subaru 2.5L 1999-2003 EJ25 Engine Rebuild Kit
the head gasket was just replaced, i believe the knocking sound is piston slap so replacing the pistons and rods is my main concern. then apparently there is metal in the oil from the rods wearing out they said. so i need a new oil pump.
so what i'm looking to do is,
1, drain all fluids
2 remove engine
3 can i flush the system to get all the metal out?
4 take apart engine following manual to the teeth
5 put in all new parts
oil pump, oil filter, rods, pistons, and all the seals
6 put engine back together
7 put engine back in car
8 Never go the that mechanics shop again.
does this sound alright?
for the site
is my car a legacy or an outback since it's a "outback legacy"
is my bore size standard?
is my main and rod bearings standard?
where is my thrust bearing? how do i tell?
rod bearing size? bigger is better, or possibility it won't fit?
like i said i'm a noob, i would surely appreciate some help here, the car is not in my possession now. the autoshop was i guess bummed they don't get to fix my car and don't want to put it back together yet. guess they didn't like it that i think i can do it, the dude pretty much yelled at me for not doing it his way.
Thanks for reading, any help would be awesome! looking forward to seeing more of this community.
1, drain all fluids
2 remove engine
for the site
