1 - 7 of 7 Posts
Subaru nation please help will an 2001 outback 2.5 AUTO trans swap into my 99 legacy outback 2.5
The trans is bad in my 99 and my friends 01 just had the trans rebuilt before crashing it
It still runs an drive btw
99 is a 2.5 dohc 16v limited trim 30th anniversary edition
01 is unkown trim with a 2.5 h4 F sohc
im new to this subie life
As far as I understand it will, on one condition that they both have thg he same front diff ratio. ( Suggestion, get the rear diff from the donor car as well. )
Sent from my SM-N950U1 using Tapatalk
'05 OB 2.5i, '14 OB 3.6R
No it won't because its different. From what i can tell the 2001 was a one year only transmission. Where are you located? I have a 98 legacy outback with a bad engine but good transmission.
Him didn't realize the did the one year only on that one. What is different about it? I knew about the phase 1 phase 2 electronics changeover during the 98 usdm model year.
Also interested in location. I may have access to a 99 trans. I am in central Texas.
Not sure the difference but i just found out that there are two different transmissions in 99. The TZ10 is 98-99 and the TZ1A is 99 only. I enjoy searching things to learn more about our beloved subarus
480838
Just trying bring this back to the top, i have a 99 outback with the JEBA tranny. It has the dreaded lag going into drive. I have a 98 tranny available but understand i need 99 -03 outback or 99-02 forester but haven't seen for sure. Does anyone know for sure?
1 - 7 of 7 Posts
