I believe you can just put an idler pulley mechanism in place of the AC pump, or, perhaps remove the belt completely. I am not sure how the 2000 car is.
Unless you are starting to take every AC component out of the car (meaning removing the entire dash and removing the AC Condenser, Evaporator, etc.), you should not affect the heat or anything else for that matter.
Of course, if you want all of the above removed, you will need to replace parts with those from a NON-AC 2000 car!
Hope this helps!
Hope this helps!
