1 - 2 of 2 Posts
2009 Outback SE
2009 Outback, 2.5, 5MT, 160,000 miles. I am currently 1,200 miles from home and my ABS & VDS lights came on. Cruise Control stooped working and rear break lights stopped working. No Subaru dealers nearby, took it to an independent shop that had an ABS scanner. All sensors scanned good, but scanner said brake switch is bad. They installed a new brake switch from NAPA, but problem remains. Any ideas ?
solve the ABS light problem, and the VDC will start working again.
(... ABS light makes the VDC off light).
could be as easy as a bad bulb,...or a bad bulb socket
is the plain "brake" light on also?
1 - 2 of 2 Posts
