Hi, does anyone know what are the correct dimensions for the o-rings that connect AC lines to the condenser? They are part numbers 73796KC000 and 73796KC020. The car is 2012 Subaru Outback 6MT Base.
Thanks.
no, unfortunately I do not. you looking to replace them?
I need to replace a leaking o-ring in the drying element header. It looks like I would need to remove the condenser for this. Once I disconnect both lines from the condenser, I will likely need to replace the two o-rings I am asking about. I have a set with 270 o-rings of different sizes, but want to check if I have the o-rings that would fit. Otherwise I might end up without o-rings that would fit after opening the system, with a long lead time to order.
Looking....and looking....and looking...and found! 2011 Outback 2.5i, 6-speed manual.
I'm looking at buying one of these kits from RockAuto. Every o-ring you should need and then some.
A/C O-ring kit
