2004 sub baja. When I run the ac sometimes a noise that sounds like a horn comes from the middle of the dash. it comes and goes and lasts a few seconds up to ten seconds. At times the belt will squeal at the same time the noise starts when the compressor kicks in but not all the time. I shut the ac off the noise stops if I shut the car off when its making the noise it continues and slowly fades away. Any Ideas
2017 Outback 3.6 Touring, which replaced '05 Outback XT
Probably a dying, vacuum operated blend door for the HVAC.
03 H6 OBW & 06 WRX Sportwagon
system overfilled with refrigerant. makes the H tube/w'ever 'hoot' as fluid instead of gas passes thru it. Not good.
'Best' to have an a/c shop recover the refrigerant and install the recommended volume.
