Does anybody know if there is a way to confirm the active grill shutter is what is causing my error code U0824 or if it could be a wire problem or battery problem?
2008 Subaru Tribeca
I've seen debris,rocks, whole peanut get jammed in there and cause issues.
I've also seen rodent damage to wires cause this issue.
I've also seen the grill fail them selves.
I can’t see any damage to either. I can move the shutters manually and when I disconnect the wire and reconnect it the shutter opens. I can tell their is a constant power to the connector and the ground is connected. What I can’t tell is if the module is giving the right signal to the shutters or if their might be more to it. Any help?
