2007 outback 2.5 basic automatic
Hello
I am planning on adding a light bar or fog lights to my 07 outback. What is the best way to wire the lights through the firewall?
Any tips would help
thank you
2006 Outback Sedan LLBean
Me too! I have wires temporarily run behind fender and into door jamb.
Sent from my V35-ThinQ using Tapatalk
2005 Outback VDC limited 3.0r
Since you have an automatic, you can pull the small rubber plug that's meant for the clutch master and drill a small hole through it, run wires. I have a 2 guage amp wire running through the grommet.
Would that be found on the passenger or driver side?
I was going to say it's the clutch oh, so it's got to be on the driver side! But reading again the clutch master cylinder could be anywhere I suppose.
It's the driver's side (whichever driving format you use), BUT the diamond-shaped grommet is actually inboard of the brake booster (rather than outboard, as one would think) due to the nature of the clutch pedal design. Either way, it's a larger (~3 in. wide) grommet, can't miss it.
