Silver 06 2.5i
Hey all you subie guru's.
I have a 06 2.5i outback 87k miles that developed an exhaust leak.
My have a split at the juction of the Y pipe that goes to both of the mufflers.
I've priced the whole pipe out and I'm looking at 250-300 depending on what online seller I use.
I took it to my mechanic that Ive used for my old job and he tried to weld it but didnt do to good of a job .
The exhaust other wise is in good shape .
So my question is has anybody else had this leak and how did ya correct it.
Thinking I may see if there are any local exhaust shops that may try and weld it again.
thanks
Mike in SJ
Take it to a good (non chain) muffler shop. the usual repair is to cut off the leaking (and usually seized) flange and weld a short pipe in its place.
2006 Subaru Outback Wagon 2.5L XT Limited
Any exhaust shop or performance shop will help you. Performance shops work on custom exhaust all day long.
2009 Subaru Outback 2.5i
I don't have any pics, but I had the same leak on mine (found it when I had to have the vehicle undergo a State Inspection). At first I tried welding into the seam, but there was no way to get a good weld in there. I fixed it by cutting a filler piece of steel and welding it in to box-in the entire rear of the Y. Has been sealed like that for 4 years now with no issues...
