Hi all,
I've tried looking around the forums for this information, but couldn't seem to find anything. Here's the question:
In the installation instruction diagram for the Hidden Hitch, it shows to install the backing plates perpendicular to the length of the frame. However, they don't seem to fit quite flush that way. Has everyone just installed them parallel with the frame? Does that question even make sense?
More info: I'm doing the inspection hole widening method using the step bit. The hitch I'm installing is the hidden hitch from etrailer.com
Any insight you could give would be great! Thank you.
