1 - 20 of 25 Posts
2011 Subaru Outback 2.5i Premium PZEV
I don't know why there aren't any threads on this, maybe I am missing something. I got 26k on my outback and haven't changed the airfilter. Was contemplating upgrading to K&N
Points
1) Will it interfere with emissions
2) Will it interfere with computer/sensors/performance
3) Will it void the warranty
For those that have the K&N please chime in. Is it worth to do it? Better performance? Better mileage??? Anyone?!?!?
There have been a couple of threads on this and IIRC it turned into a "best thing since sliced bread vs snakeoil" pi$$ing match.
Fresh Out of Outbacks!
There are several threads for intakes, performance filters, K&Ns etc.
The short version: No, maybe & no. An over-oiled filter element can foul a MAF sensor. A clean filter is better than a dirty filter, and nobody in a Subaru ever got a K&N to pay for itself vs. stock. They still look cool.
It will not add any performance at all, and it will likely let more small particles through. Whether those tiny particles do much harm is up for debate.
I have used them in the past. I do not use them anymore, because the MAF sensors tended to get dirty when the filters got more that a couple cleanings behind them. So, I do not consider them effective, long term. The paper stockers are guaranteed to stop dirt, and the K&Ns are not as permanent as advertised. Your money, your choice.
Meh.
I has wagons.
There are probably a dozen threads on this.
But:
No.
Maybe.
No.
Ok guys. Thanks for the help. I tried searching, but btw the search function capability and the slow website, i was unable to fin dany threads.
Thanks a lot for the responses. I will pursue a regular paper filter. Dealer told me to change mine every 15k, this true, lol it looks like a way overshot it
15k for the cabin filter, 30k for the engine air filter. I changed mine at 25k, and it wasn't in bad shape. I changed the cabin filter at 15k......It was pretty bad. I live in NM where it is dusty.
Weird, maybe she was confused. She was telling me 15k for the cabin filter (didn't change yet- looks ok still) and the air filter for the engine
2014 2.5i Limited
I have the K&N and the only thing you gain is knowing you are not throwing something in the trash every 15k miles. If you live in/drive in dusty conditions and want to use one you might want to consider a pre-filter or another brand of washable filter.
**Before reading please note that there is no place that has more BS on any automotive forum than a K&N air filter thread, so take my statements at face value**
All the K&N will do is allow more dirt thru your engine.
Modern FI systems meter the amount of air that comes in and adjust the fuel mixture accordingly, so letting more air thru is unlikely to cause an increase in performance of significance unless a severe restriction was engineered into the intake from the factory, which it was not.
I had several K&N filters over the years, I now use stock paper filters in all my cars, including the Porsche track car. After looking at my intake and seeing the throttle body full of dirt I decided that the benefits are minimal relative to the potential damage.
...uh huh...and IMHO I think that they really are not worth the extra $$$. The OEM filter will do the same thing...filter the air before it ienters the engine for combustion. Snake oil.
2013 Outback 2.5i Premium
The only vehicle I have with a K&N filter is my motorhome. The V10 engine in this beast is so far away from any possible cool air supply that they had to do a several feet long run to the front, to get enough air into it, and it has a factory installed K&N filter (this one has the size of a small wet and dry vac)!
Meh.
I has wagons.
I'd had Fram, STP, Purolater, Wix...never could tell any difference.
2005 3.0 R n totaled
I hear/read same things as Rasterman - there are some reports that K&N filters compromise MAF sensors - some manufacturers (VW Tdi) specifically warn against using them.
1 - 20 of 25 Posts
