Dear All,
I have an issue with my rear windshield defogger. I looked at a couple of previous threads including the one shown below,
http://www.subaruoutback.org/forums/80-electrical-electronics/51198-2005-outback-rear-window-defogger-not-working.html
Based on the above, and few other threads and FSM I did the following diagnosis.
1. Checked fused M/B 10 and F/B 22 (A/C fuse) and they are both good.
2. Defogger switch seems to be working fine as the yellow light comes when both fuses are in (not when one of them is out.)
3. Continuity between left and right terminals is rear defogger grid is good.
4. No voltage across the same two terminals when defogger is turned on.
5. Checked the wiring at all 4 boots at the rear hatch. They seem to be fine with wires inside the insulation except on right lower boot where wires are exposed, but, no visible damage.
based on the above should I replace the relay or should I rep the rubber wiring case apart and check for broken wires?
