2004 Outback Wagon H4 5spd
I'd like to hear from anyone who's added an oil pressure gauge to their Outback.
I hope to find an an easy way to adapt the stock pressure switch location without screwing together all kinds of fittings. Also, I haven't found any A-pillar gauge pods for the Outback, anyone know if pods for other Subaru models will work?
rob
Superb Moderator, ,
MY12 WRX, MY07 FXT
I have. An Autometer Pro Comp electrical. Remember now, MY02 2.5, I tapped into the oil gallery on the top of the engine under/near the throttle body. There is a plug there with an allen hex insert to unscrew it. Subaru makes an adapter that goes right in that hole and is threaded on the inside for the sender's threads.
That's what I did, quite easy after all the research to do it. You have to know the thread type/size of the sender and screw them together. Works great.
Subaruwrxparts.com
It's called 'oil gallery plug' and it's at the end of the page listed above.
Brian
Outstanding Brian, just what I needed, thanks! I have an '04 2.5 so I imagine the setup is the same. I'll take a look when my wife gets home with the car tonight.
Where did you mount your gauge?
rob
Superb Moderator, ,
MY12 WRX, MY07 FXT
I have an OBS, so I used the Subaru center gauge pod with three gauges. It's an option with the WRX for the gauge pack. I bought the factory empty housing, a faceplate and did it myself. I built mine for cheaper, with better gauges. Maybe one of these years I'll take pics of things like that to share on the web! Brian
Yes, Brian your gauge pod looks really good.
