1 - 9 of 9 Posts
2000 Subaru Outback Wagon
Anyone ever see anyone do something like that? The idea just popped into my head, Because i want some aftermarket speakers but i don't want to lose the room in my car...
2011 Outback 2.5i Premium CVT PZEV
With a vehicle I previously owned, I had subwoofers under the rear seats. The sound was great and they basically took up zero "usable" space.
In my 2004 L.L. Bean I had an 8" Sub just barely fitting under the passenger's seat. Problem with that car is how little space there was under the seat...
In my 2008 I have the factory sub under the driver's seat.
What size sub did you have in the 04?
2013 Outback 2.5 Premium
Sub ONLY under a seat. Bass isn't nearly as affected by blockage to the listening area and absorption from materisal as midrange and tweeters.
Subie has an under-the-seat subwoofer available after market. JL Audio also makes one. I don't know if it fits, but it's a far higher quality brand. Look for JL Audio dealers - they are usually a pretty smart set.
EDIT: I'm saying only a sub should be placed under a seat - but not saying that is the only place it should go. There are other placements that would likely sound better. Never put any speaker except a subwoofer or transducer under a seat.
Eh i figured i'd have to take the seat out to install it anyway.
Right, but even when you do that it's a tight fit. On the passenger's side, the seat is more difficult to move back and forth once the sub is installed. It didn't mess with any cables or connectors for the air bag, heated seat, etc., but it's not 100% ideal. I don't think it would fit under the driver's seat. I believe there is slightly less room due to the motor for the power seat.
You do not want to have mids or tweeters under the seat, because as you rise in frequency, the placement and direction of the speaker becomes more critical for a good sound image. The way sound propagates is your limitation. That's why the stock tweeters are usually located at the front corner of the windows on the doors or the pillars in newer cars.
1 - 9 of 9 Posts
