2008 Outback non-turbo 5-manual
I was trying to make my 2008 Outback slide on snow packed roads this morning. When I pushed hard on the break peddle I felt a vibration and heard a clatter. Is that how the anti-locking breaking system is suppose to behave?
Yes, and I've found that when I was sliding on a snowy road, applying the brakes too hard caused the ABS to kick-in and the car kept sliding, scaring the poo out of me as I started to drift into an intersection. Now, I gently use the brakes in snow and if the ABS starts to come on I let up off the brake peddle and start applying soft pressure again. Of course, if it is dry or just wet roads I use the ABS as it was intended, being able to steer while panic braking.
05 Xt beatin' to an inch of its life
^Agreed. The abs strategy can be awful in more situations than it should in this model Outback.
2008 Subaru Outback Touring Diesel 5MT
You should also know that ABS won't work if your doing less than 10 km/h. I had to figure that one out during an less than ideal situation.
