Fun.
Replaced the toasted stock AT from a 96 OB 2.5 (225K miles, 4.44 final) with an AT out of a 98 OB 2.5 (165K miles, also 4.44 final).
The original trans had been destroyed by some kind of off-road enthusiasm: the exhaust was snapped in two, the heat shield mauled, and the trans output shaft snapped-off in the rear driveshaft yoke. Sounded like a fun adventure. Wasn't there... sour grapes.
So, in goes a " told good " AT out of a non-GT 98 OB.
Wow. In order to get it on, I had to grind-down the Outside Diameter of the yoke on the rear driveshaft that slides over the trans output shaft. Many grey hairs isolating that fact.
THE PROBLEM IS, now the trans only shifts from neutral-first; no reverse or park. Please tell me that there's something simple that I'm missing! Where do I sprinkle fairy dust and wave a magic wand to get the trans to physically shift into reverse and park?
I have the car up on 4 stands, have tried disconnecting the linkage and shifting manually, still no movement beyond the neutral position.
What has me pet-ree-fied is that the old, beat AT sittin' off-vehicle will manually shift through all the gear positions quite easily. This allows me to compare the relative armature positions for various gears, and confirms that the installed '98 isn't shifting backwards from neutral to R or Park. ****!
I also substituted the original known-good trans gear position switch and simply plugged-in from above in the engine compartment in order to be able to have easy access for manually flipping the switch through the gears. With all wheels up, this simplified fooling the starter cut-off switch into letting me start the engine in any gear which was very helpful to confirm what shifter position equalled precisely which actual gear.
I'm really, really, hoping that there's a simple way of reminding this trans that it has a Park and Reverse. M'Aidez... errr, Mayday!:gasp:
Thx
