1 - 7 of 7 Posts
2010 4 cylinder 251k miles. Subaru replaced the cvt valve body a few years ago. I was pulling a trailer today, and on the return trip from where I was going, the at temp light started flashing. There was no noticeable difference in performance. At that point I pulled over to let the transmission cool off and found out that I could not shift from drive to reverse. I could shift from drive to neutral and then it feels like I hit a brick wall. It will not even come close to going into reverse or Park. At that point I drove about 30 more miles home with no problems but I still cannot get the car in park and the key is stuck in it. When I was almost home I also noticed that my turn signals were not working. I'm pretty sure these did not go out at the same time as the transmission light came on. Any ideas?
Check fuse #20 (15 Amps) "Turn and hazard warning flasher (body control unit)" in the engine compartment fuse box. (Page 12-9 in your Owners Manual.) It also powers the Shift Lock control, which is what allows/prevents the gear selector from moving between N and R.
Also, see pages 7-20 and 7-21 in regard to releasing the Shift Lock when it doesn't function normally.
2014 Outback, 2.5 Premium / CVT
Might want to check the trailer lights / wiring. There may be a problem there that caused the hazard fuse to blow. (I've got one of 3 trailers that is causing a couple fuses to blow every time I plug it in on my truck. Lucky that the trailer lights have dedicated fuses in the GMC. Time to rewire a trailer?)
Yeah, I haven't plugged it back in since.
Are you using a trailer wiring adapter?
If the connector going to the trailer is hard-wired into the Outback's lighting circuits, then a short in the trailer could blow a fuse, as in this case, the turn signal etc., fuse. However, Subaru provides a trailer wiring connector in the cargo area, and when fitted with a trailer wiring adapter (as is recommended), faults in the trailer wiring will cause a separate, trailer adapter fuse to blow, but not disable any of the car's circuits.
This is great everyday info that we all should know...thanks for this. :)
1 - 7 of 7 Posts
